Ansys Learning Forum Forums Discuss Simulation Photonics Updating a Lumerical example Reply To: Updating a Lumerical example
sara.bassil
Thank you so much that helped !!
I am first doing the sweep over the gap to extract the final E matrix (Ef) of dimension (length(datapoints), 3, length(gaps))
However the datapoints don't have the same length for each gap
So I chose to cut the extra values :
For example if ?size(E) ; = (1450,3)
I did this : Ef(:,:,i)=E(1:1400,:)
with Ef = matrix(1400,3,length(gaps))
So once I have my final E matrix I do a sweep over the gap to compute the perturbed index.
However when I want to use the function addattribute I have this following error : matrix for addattribute does not have the correct size to match the dataset
I think it's because the dimension of my final E matrix is : (1400, 3, length(gaps)) and not (1400, length(gaps), 3)
Is there a way I can add the attribute to the electrosattics dataset ?
My next step is to use the FEEM script and modify it as well to obtain the Vpi and the losses in function of the gapÂ
