Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Particle surface reaction › Reply To: Particle surface reaction
December 19, 2024 at 11:47 am
Particle reactions would tend to be DPM, which isn't Euler-Euler multiphase. However, you can react the latter too. As a starting point work out what you need to find out from the model, and what the boundary conditions would be. What is the solid volume fraction, and what happens to the particles as they react?Â
