Ansys Learning Forum Forums Installation and Licensing Ansys Products Beam Connection for Three Plate Reply To: Beam Connection for Three Plate
brandonturner178
I'm performing explicit finite element analysis using shell elements and need to reduce computation time. I've constrained the first and last plates using beam elements, but I'm unsure how to effectively constrain the middle shell plate. A solution to this constraint issue is required. retro bowl
