Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Problem to add result to parameter sweep edit window › Reply To: Problem to add result to parameter sweep edit window
December 17, 2024 at 9:53 pm
Amrita Pati
Hi Leroy,
Unlike FDTD, you would have to run the simulation first (be in the analysis mode) to be able to select the mode results in FDE. And then you can select the result from the sweep. So, I will recommend running the simulation and then going into the sweep and selecting the desired result.
Amrita
