Ansys Learning Forum Forums Discuss Simulation Electronics Modeling of nanocrystalline material using homogenization technique Reply To: Modeling of nanocrystalline material using homogenization technique
GLUO
I think you could use a simple material to check if the inductances are same to rule out other possible cause first. If they are the same, then you can inspect if the coordinates and material are set correctly. I suppose you are using cylindrical coords for the 4 corner parts?
GL
