Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to build different rotor geometry in Ansys Maxwell › Reply To: How to build different rotor geometry in Ansys Maxwell
December 16, 2024 at 2:46 pm
Hi melihstorm1,
 To make any modifications to an existing model in Maxwell. You can use the tools available under the Draw tab and the boolean operations.
If you have a complex geometry, it is advisable to model it using a CAD tool and then import it to Maxwell.
Navya
