Ansys Learning Forum Forums Discuss Simulation Fluids Slanted bottom level Reply To: Slanted bottom level
s.m.mousavi
So, if I understood correctly, you are suggesting decreasing the time step? I have already tried several time steps, I always got the Floating Point error. The only case I could run the simulation successfully is when I am reducing the wave height from ~ 9 cm to ~ 5 cm.
Or what are the other suggestions to overcome that error?
