Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › The equation of MAT58 in LS-DYNA › Reply To: The equation of MAT58 in LS-DYNA
December 13, 2024 at 7:47 pm
Pedram Samadian
Hi Linjun,
You do not have to put any values for those 3 parameters based on the samples I have. Have you run the model to see if LS-DYNA gives you an error? By the way, the TSMD has a default value of 0.9. If you are not sure what value to be given to it, leave the default value there.
Thanks,
Pedram
