Ansys Learning Forum Forums Discuss Simulation Fluids Getting started in the use of supercomputers to simulate in CHemkin Reply To: Getting started in the use of supercomputers to simulate in CHemkin
Ren
Chemkin does not run in parallel except for parametric studies where multiple parametric runs can process  in parallel. Therefore, Chemkin is typically run on a desktop computer and does not requrie a supercomputer. If you really want to run Chemkin in batch, you can prepare the run interactively on your desktop and then use the commandline to run in batch. You can find information on the Chemkin commandline interface in the user guide:
Chapter 4: Using the Command Line
