Ansys Learning Forum Forums Discuss Simulation Electronics How to rotate cut out model from board file to right angle Reply To: How to rotate cut out model from board file to right angle
Yang Zhao
Hi Franc,
For an Object without Angle property, we can select it to display a rotated icon (green box in the middle of the figure below), and then manually rotate the Angle.
1. Select the object you want to rotate.
2. Drag the circular part of the rotation handle in the direction you want to rotate the object.
[Key Point] The default Rotation Increment is 5 degrees, which can be modified from the Layout Settings -> Other. Change the increment to a smaller value if we want to get an accurate rotation.
Yang
