Ansys Learning Forum Forums Installation and Licensing Ansys Products Regarding the mesh accuracy related issues in HFSS and AEDT Icepak electro-therm Reply To: Regarding the mesh accuracy related issues in HFSS and AEDT Icepak electro-therm
Rabindra Paul
Hi, Thanks for the comment. The scaling factor is 1 by default, which means the power values ( EM loss) from HFSS will be used as is for the Icepak simulation. However, to model worse case scenerio, users may use a factor more than 1. More power ( or scaling factor >1) should provide higher temperature than default 1, if everything else in the simulations remained the same. Please feel free to contact support through support portal if there are any concerns with the results.
Hope this answers the question. Please let us know any comments.
