Ansys Learning Forum Forums Discuss Simulation Photonics Lumerical to Heat Reply To: Lumerical to Heat
kghaffari
With FDTD simulation you can obtain the spatial absorption profile of your device. You can import this data into Lumerical's HEAT solver to obtain thermal profile. An example of this type of workflow is demonstrated in the following application example.
Regards
