Ansys Learning Forum Forums Discuss Simulation LS Dyna Johnson-Cook material strength model and the Johnson-Cook fracture model. Reply To: Johnson-Cook material strength model and the Johnson-Cook fracture model.
kikuji.yuki.r3
Thank you.
The left image shows the case where the Johnson-Cook failure model is used, and the right image shows only the Johnson-Cook material strength model without using any failure conditions.
The analysis was performed using SPH.
