Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Importing a CFD pressure load to Mechanical using Scripting › Reply To: Importing a CFD pressure load to Mechanical using Scripting
December 10, 2024 at 8:25 am
Erik Kostson
Hi
Do not think that (choose cfd surface) is exposed .
I believe the imported pressure load picks up the first cfd surface (in alphabetic order) from your named selections (ns) in the cfd simulation so if you call it acfdsurface it should pick it up automatic (the rest would be wall, inlet, and outlet ns so it will be first in that order and will be asigned to the imported pressue load added and under cfd surface).
All the best
Erik
