Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Which heat source model does ansys use in DED additive manufac. in mechanical? › Reply To: Which heat source model does ansys use in DED additive manufac. in mechanical?
December 10, 2024 at 7:17 am
Hi Monis,
You can find all the details for analysis settings in this Ansys Help Document: 16.1. Analysis Settings for Most Analysis Types
Look for 16.1.3. Solver Controls, 16.1.10. Radiosity Controls & 16.1.15. Nonlinear Controls. Let me know if this helps you or you need any additional details.
In case you are unable to access above links to help document, you may refer to this thread: How to access the ANSYS Online Help
Thanks!
