Ansys Learning Forum Forums Discuss Simulation General Mechanical APDL – how to access Sweeping Phase in Harmonic Response Reply To: APDL – how to access Sweeping Phase in Harmonic Response
ErKo
In mapdl we get real and imaginary part of a harmonic solution/result, or amplitude and phase (we set that with SET command) so there is no similar (sweeping phase) option in MAPDL.
In mapdl a macro is used for plotting called anharm.mac – very complex but you can have a look at it.
If this or macro does not help then open up a support request with the channel partner or with Ansys support, and we will try and help you (find a workaround etc.)
All the best
Erik
