Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Remote point and thermal condition (thermal expansion) › Reply To: Remote point and thermal condition (thermal expansion)
December 6, 2024 at 3:31 pm
I think the use of beam behavior could be causing the problem. Creating hundreds of beams between the remote point and the scoped surfaces could be ruining the solution. If you use deformable behavior you will get a heat and force balance between the point mass and the surfaces.Â
