Ansys Learning Forum Forums Discuss Simulation Photonics Running an Optimization Across Many Nodes on a Cluster Reply To: Running an Optimization Across Many Nodes on a Cluster
Lito
@scorsett
To debug the issue, please assist us with the following:
  • Your example shows you are running with OpenMPI. Did you install and configure OpenMPI on the cluster?
  • Can you run a simulation file (.fsp) on the cluster? If yes - how are you running the simulation file (.fsp) on the cluster?
  • Do you have a GUI Connection to the cluster? Are you running the simulation/job from the Lumerical CAD/IDE?
  • Or do you submit jobs with a SLURM submission script?
  • Are you running the Lumerical script.lsf the way?
