Ansys Learning Forum Forums Discuss Simulation Photonics Errors Running Ring Modulator Example on Cluster Reply To: Errors Running Ring Modulator Example on Cluster
Lito
This is to verify if you can run the simulation file using Local Computer as the job launching preset. The error message on your post was referring to MPICH2.
ldev error:
"/software/lumerical/2021r2/lumerical/v212/mpich2/nemesis/bin/mpiexec" -n 1 "/software/lumerical/2021r2/lumerical/v212/bin/device-engine"
"/projects/NODE/USER/TrialRuns/RingResonator/c118296f-ring-modulator/waveguide_modulator.ldev"
