Ansys Learning Forum Forums Discuss Simulation Photonics Errors Running Ring Modulator Example on Cluster Reply To: Errors Running Ring Modulator Example on Cluster
adevata
Just to confirm, are you talking about the settings that I currently have configured? Or the ones that you had sent initially?
Also, by simulation (waveguide_modulator.ldev), do you mean to go to the CHARGE tab, then in the simulation section on the right, click the run button? Or is this a command I should be entering into a job terminal somewhere? I'm guessing its the first since I'm launching the Lumerical GUI as a job.
Thank you!
- AD
