Yang Zhao
Hi Fran,
I see that you changed the unit to mill after adding a variable. It would be fine. But it is better to check the unit of the Evaluated Value again.
We can also try to use a Void Rectangle instead of a Polygon first if you just want to get a rectangle void.
