Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Thermal analysis problem › Reply To: Thermal analysis problem
December 4, 2024 at 10:07 am
In a sealed domain you need ideal gas. Incompressible ideal gas would be the correct choice in an open domain.Â
Solid-fluid nonconformals are a little special and I'd avoid when learning to use the software. Read up on share-topology.Â
