Ansys Learning Forum Forums Installation and Licensing Ansys Products Mechanical only opening in Read-Only/unlicensed Reply To: Mechanical only opening in Read-Only/unlicensed
Matt
Hi George,
Thank you for your suggestion. I managed to open the files in MS Word and there doesn't seem to be any errors given.
Essentially, the log states:
Starting licensing client, started ANSYSLI server, Client_Connect, Connected to Licensing Client and then Client Exit (assume when the program is closed)
