Ansys Learning Forum Forums Discuss Simulation Preprocessing Assiging one parameter as thinkness of few shell objects Reply To: Assiging one parameter as thinkness of few shell objects
Govindan Nagappan
I have 2 parameters(p1 and p2). Using expression, I have set P2=P1. Notice P2 is greyed out. In the table of design points, you will have to modify only one parameter which is P1.
You can use mathematical expressions
For more details, check Expressions, Functions, Quantities, and Units
