Ansys Learning Forum Forums Discuss Simulation Fluids Water surface at a specific location Reply To: Water surface at a specific location
SRP
Try to create the line/rake at the location. You can create surface monitor with field variable phase - volume fraction for the create line. This will helps you to monitor the water at the paticular location on the basis of volume fraction
