Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Solving multiple design points is extremely slow › Reply To: Solving multiple design points is extremely slow
December 1, 2024 at 6:11 pm
esbenn
I am also having that experience with updating design points from workbench instead of manually doing it in Fluent. I'm running a simple flow simulation on the DES realizable k-epsilon model across a bunch of different flow speeds. Running it manually takes 10 minutes max but updating design points instead takes like 5-10x as long per design point. I've only got 1 million elements in my mesh too, so not it's not a crazy demanding use case either.
