Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LS-RUN freezing › Reply To: LS-RUN freezing
November 30, 2024 at 8:48 am
Thank you for your assistance. With guidance from the DELL technician, we confirmed that the hardware of the Alienware system is functioning normally. Therefore, the issue must have been related to the system itself. However, we are still unsure about the exact cause of the problem. After resetting the system to its factory settings, the issue has been resolved.
