AntKou01
I have had the same problem, but i have unistalled previous ansys versions and deleted the related files from the system (meaning C:\Program Files\Ansys). I had the 2022r2 working on Mechanical APDL then the licence expired, I installed the 2024r1 for FLUENT which worked fine, but then working on FORTE I had that FNP licence error. I uninstalled it and removed the relevant files and reinstalled 2024r2 with the same error appearing even on the FORTE .ftsim tutorials (by the way on 2024r2 FLUENT works fine). Is there a posibility that there are variables in the system or files located somewhere else that must be deleted or renamed, because they conflict with the fromerly installed program? And if so what could i do?
Kind regards, and thanks a lot.
