Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Total pressure data of the simulation is not correct. › Reply To: Total pressure data of the simulation is not correct.
November 28, 2024 at 5:10 pm
Respected Sir,
P0 is a constant value. If we non-dimensionalize total pressure by dividing P0 (Constant Value) then the pattern will be the same, of course the value will be some another value. In X axis in published data, it is x/D, which is also non-dimensionalized.Â
Although, I have attached a comparison plot for your clarity and better understanding.Â
Thanking you sir.
