Ansys Learning Forum Forums Discuss Simulation LS Dyna Uniaxial tension does not work in LS-Dyna ACT Workbench Reply To: Uniaxial tension does not work in LS-Dyna ACT Workbench
Ram Gopisetti
How stiff is your tested material? Have you tested with tet elements? If so, can you post your results?
Cheers, RamÂ
