Ansys Learning Forum Forums Discuss Simulation Fluids Heterogeneous Reactions Reply To: Heterogeneous Reactions
OK, I had the option, didn't and now do. I wonder if the number of species involved or "something" has messed with the GUI panel. Can you check the TUI command
/define/phases/set-domain-properties/interaction-domain/heat-mass-reactions react , yes
And just accept everything but the Arrhenius setting.
