Ansys Learning Forum Forums Installation and Licensing Ansys Free Student Software need help with rotor simulation — solver did not run Reply To: need help with rotor simulation — solver did not run
jkl6588
Thanks for replying @Harrygross616.
I've gotten to the point where I've smoothed out what are most of the error messages, but am left with just these errors:
 *** WARNING ***                         CP =       2.380   TIME= 02:42:26
 Material property ALPX of material 3 is evaluated at a temperature of
 22, which is below the supplied temperature range.  Temperature range
 checking terminates.
 *** WARNING ***                         CP =       7.319   TIME= 02:42:27
 The Memory_Option on the DSPOPTION command for the distributed sparse
 solver should be either DEFAULT, INCORE, OUTOFOCORE or FORCE.  This
 field is reset to DEFAULT.
 *** WARNING ***                         CP =       9.234   TIME= 02:42:28
 Element shape checking is currently inactive.  Issue SHPP,ON or
 SHPP,WARN to reactivate, if desired.
 *** WARNING ***                         CP =      29.018   TIME= 02:42:36
 Contact element 360581 is missing DOF TEMP (and possibly others) of
 underlying base element 48108.  Similar mismatches may exist
 elsewhere, but checking for this is discontinued.
 *** WARNING ***                         CP =      67.411   TIME= 02:42:56
 For element 220842 the element connectivity is 0 and 286092.  The node
 which is identified as a 0 will be a grounded node.
 *** WARNING ***                         CP =      95.564   TIME= 02:43:04
 Coefficient ratio exceeds 1.0e8 - Check results.
 *** WARNING ***                         CP =     120.530   TIME= 02:43:25
 Pivoting has been activated for the Sparse Matrix Solver .  The memory
 required may greatly exceed the predicted amount.  In that event, use
 the DSPOPTION command to change the memory mode and/or memory size
 used by the Sparse Matrix Solver.
I am not entirely sure just how to find these specific elements that seem to be grounded or don't have their thermal DOF turned on (although both of my frictional contacts have them as per the tutorial).
The other very worrying thing is the ground node, definitely should not be fixed at all anywhere...
my mesh solution asdp already has dspoption,,high -- so its probably the two elements causing the matrix to be very sparse and fail.
