Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The FLUENT Application is currently busy. Please try this operation again after › Reply To: The FLUENT Application is currently busy. Please try this operation again after
November 26, 2024 at 5:36 pm
That usually means a part of the process has ended. Given the model is "stuck" I suspect part of Fluent has failed. You may need task manager to kill the process.Â
