Ansys Learning Forum Forums Discuss Simulation Fluids Issue with contour discontinuity while using dynamic mesh. Reply To: Issue with contour discontinuity while using dynamic mesh.
z5456415
Yes, Overset mesh, where the dynamic motion is defined using the Dynamic mesh option (not using cell zone conditions). I did this because later I will need to prescribe/define motion passively using an equation.
I do not know how to check for orphan cells. Could you please advise me on this? when I am using "/define/overset-interfaces/check" the console shows as below
And when I checked Mesh under graphics  it displayed the overset mesh as below.
It would be so helpful if you could help me on this.
