Ansys Learning Forum Forums Installation and Licensing Ansys Products Tutorial or Help for 2 way FSI Reply To: Tutorial or Help for 2 way FSI
ashishkumar.gupta
So rotational velocity in Mech will NOT cause rotational movement of the IR ??? Then what is the use of using rotational velocity??
I want my IR to rotate in Mech --> This will cause the Ball to rotate to in Mech....See this Mech. Setup using Frictional Contact and Circumferential Disp.. ---> https://youtu.be/u3xhsZsvK2Y
Also the Races and Ball are penetrating if you see the Video URL (https://www.youtube.com/embed/G9SG7Z4Cpec)
The Ball is also not moving in Fluent.
Even tho the simulation completed, the results are pretty bad.Â
