Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Tutorial or Help for 2 way FSI › Reply To: Tutorial or Help for 2 way FSI
November 25, 2024 at 10:40 am
Hi Ashish,
That's good news.
Why do you have a deforming volume in Fluent? All volumes are deforming by default there is no need to explicitly set it.
No rotational movement where: the ball, the IR or both?
The IR will not rotate since you are using rotational velocity, which doesn't rotate the mesh as I've said.
The ball should be able to rotate, but whether or not it does will depend on the forces it receives. Does it receive a torque from the fluid? You need to be monitoring this in Fluent.
Paul
