Ansys Learning Forum Forums Discuss Simulation General Mechanical Nonlinearity convergance problem Reply To: Nonlinearity convergance problem
sypniewski
I will try to use your advices and tell you if it helps. Also, I share a link with the archove of the simulation if you would like to check on your own.
link: https://drive.google.com/file/d/1lE8NXBaoHRWkU-3s8vWF3BKCoxxVfRsg/view?usp=sharing
