Ansys Learning Forum Forums Discuss Simulation LS Dyna Problem with restart LS-DYNA & PolyUMod Reply To: Problem with restart LS-DYNA & PolyUMod
valerym.m5
the step of recording the results will be 1E-5 from 1 to 1.0001 seconds!
but it turns out that this is not so…
then how?
WHERE in the documentation is there something unambiguous / understandable:
How exactly does the ls-dyna perceive the information specified in the curve???
of course, I can "play"... - make a tiny step at the end of the implicit solver's solution time - before switching to the explicit solver....
but I want to understand = how to use the "curve" command?
how does ls-dyna perceive and interpret this command?
after all, it’s important to understand!
okay – when it concerns the output of results
but WHAT and HOW does ls-dyna do – when the load is specified as a curve?
How does ls-dyna perceive/interpret information on the load specified as a curve?
