Ansys Learning Forum Forums Discuss Simulation Fluids Failed to generate surface mesh Reply To: Failed to generate surface mesh
tr760256
I've done share topology and it was successful.
I did pmdb file because in one of the tutorials for in the ansys channel, it says the pmdb file will be better. I am not using Linux. As for the solid parts, they are excluded from the simulation and only the enclosure will be used in the simulation.
