Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Errors Running Ring Modulator Example on Cluster › Reply To: Errors Running Ring Modulator Example on Cluster
November 21, 2024 at 8:51 pm
kghaffari
Thank you for the update. Yes, I recommend just running the CHARGE simulations for your troubleshooting and avoiding the extraction sweeps for now.
Are you running the simulation on cluster from the CAD or from the command line with a job scheduler? If using a job scheduler, please share the submission script so we can comment.
 Please note that CHARGE can not run on multiple nodes. So you will have to request 1 node on the cluster and use all threads/cores on that 1 node. If you are using multiple nodes, this may be causing the error.
Best,
Khash
