Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Mohr_Coulomb material model (MAT_173) › Reply To: Mohr_Coulomb material model (MAT_173)
November 21, 2024 at 4:31 pm
Please check the following thoughts about the possible sources of error:
- Ensure you are outputing a right variable for the shear stress. The "maximum shear stress" needs to be output, not any shear stress components in the stress tensor.Â
- Revisit the input material parameters in the material card and verify their values and unit consistency. LS-DYNA Theory Manual and Keyword User's Manual (LSDYNA Manuals) are good resources for the better understanding of this material card and its parameters.
- Make sure that the material passes the yield strength.Â
- Use a fully integrated elemen type.
- Run the model with multiple elements to see if you can get what expected.
I hope there are helpful.
Thanks,
Pedram
