Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Gaps in self-made car jack › Reply To: Gaps in self-made car jack
November 21, 2024 at 11:51 am
In this model, why are you using bonded contacts? You should insert appropriate Joint Connections at all the joints in the model.
For more information about joints, please go through the following links:
9.7. Joints
https://www.youtube.com/watch?v=il_OfGcXWYw&list=PLtt6-ZgUFmMKdzJIohbfiQyYSCAU42ZAO
Also, I can see that there is a penetration between two parts. This should be rectified in a 3D software.
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
