Ansys Learning Forum › Forums › Discuss Simulation › Fluids › FLUENT | Mass flow-rate report at inlet surface different to the specified value › Reply To: FLUENT | Mass flow-rate report at inlet surface different to the specified value
November 20, 2024 at 10:01 am
With 3D that should work as you're reporting the same surface. How do the other boundaries tie up with the reports?Â
