Ansys Learning Forum Forums Installation and Licensing Ansys Products Fluent 22R2 on HPC slows down by time Reply To: Fluent 22R2 on HPC slows down by time
You shouldn't need any remeshing if you're using sliding mesh interfaces. If you're recording images that can cause memory leaks in older builds, I can't remember if 22R2 suffers from that. The issue sporadically reappears as option interactions with OS/drivers etc come up.Â
