Ansys Learning Forum Forums Discuss Simulation General Mechanical Diffuse Sound Field Settings Reply To: Diffuse Sound Field Settings
z.aniretaj
Hi Erik
Thank you for your response!
  1. Is DSF used exclusively for evaluating Transmission Loss (TL)?
  2. What if I want to calculate the response of a body placed in a reverberation chamber? From what I understand, a diffuse sound field is created in such a chamber, correct? I would like to set the conditions to see how the body vibrates, and then compare those results with experimental data.
  3. Does this mean I’m misunderstanding the kinds of problems where DSF can be applied?
Thank you in advance for your clarification!
