Ansys Learning Forum Forums Discuss Simulation Photonics How to use SHG_WGD element in INTERCONNECT ? Reply To: How to use SHG_WGD element in INTERCONNECT ?
Kyle
The SHG waveguide should work with just a CWL and an OSA. The second harmonic power may be lower than the “sensitivity” property of the OSA. Try reducing the “sensitivity” property of the OSA to see if the second harmonic appears. If you change the units from dBm to W you can set the sensitivity to zero.
