Ansys Learning Forum Forums Discuss Simulation Fluids The behavior of the external fluid does not coincide with the rotor with involut Reply To: The behavior of the external fluid does not coincide with the rotor with involut
josue
Here you can see something clearer, however it is assumed that the external area should have speed due to the rotor rotating, which is only seen to be concentrated inside the envelope.
