Ansys Learning Forum Forums Discuss Simulation General Mechanical Crack Extension in a Compact Tension Model using SMART Crack Growth Reply To: Crack Extension in a Compact Tension Model using SMART Crack Growth
Sergio Blanco
Hello Stella,
I'd like to ask you a question regarding your statement "Crack Growth is directly controlled by the number of substeps". I am too starting to work with SMART fracture in Ansys and I am obtaining very different results when I reduce the time substep (or increasing the number of substeps). At the end, should I converge to a solution when I use a substep time small enough or the solution with the SMART module is dependent on the number of substeps used?
Thank you very much,
Sergio
