Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Fatal Error while Solving the Model! › Reply To: Fatal Error while Solving the Model!
November 15, 2024 at 8:55 am
Not sure about the error (likely as you saw due to the fracture object) .
More important here, one should not be using any fracture objects on cement (they are not for concrete cracking, and would not be very good to use there I would imagine).
for cement/concrete cracking see the microplane model also used in an example in the help manual (search there for : Chapter 54: Reinforced Concrete Joint Analysis)
All the best
Erik
