Ansys Learning Forum Forums Installation and Licensing Ansys Products Tutorial or Help for 2 way FSI Reply To: Tutorial or Help for 2 way FSI
ashishkumar.gupta
The ball in  FLEUNT should either be 'STATIONARY' or if 'MOVING' should be given some values as you now....so I am asking you that should I then keep:
Fluid_Ball_surface_velocity_BC_Fluent = Stationary ?????
I hope this is wat u were suggesting and I hope this can run successfully then....
